hows it im checking the ti system on my 85 gl, just need to clarify a picture or two
with the key off, ground of DMM too negative terminal of battery it reads 000.0
with the key on it reads 005.4mV
is this an earth fault or is it to be expected?
i guess what im asking is should the frame read a mV reading normaly ?
main fuse is 12.5 as are the ignition modules on the black\white wire and around the same reading +\-
