reinsert old plug. use solvent of Cochise and a "bottle brush" make sure the drain hole is not plugged
Wow, yeah, I didn't realize there is a drain hole and it's definitely plugged by some tiny critter that made a mud nest. I guess that's why this problem happened. my stock rubber boots are fairly decent, but I think this bike was left uncovered for at least a decade before I got it. It ran very well last fall when I got it running Thanks!reinsert old plug. use solvent of Cochise and a "bottle brush" make sure the drain hole is not plugged
Just lazy while on vacationGoogle never offered that answer.
Are you sure?![]()
I think that's exactly what happened. At any rate, after reading in the work manual and discovering the cylinders can be removed while the engine is on the bike, I've decided to just play it safe and remove the heads. This way, I can also inspect my valves and get them reseated or lapped, and maybe get my cylinder walls honed, and grease the pushrods and whatever else maintence the book recommends.The boots at the top of the spark plug wells don't keep water out, just objects so it isn't surprising that the well would fill up if the drain hole was blocked. Do you have dauber wasps in your area? A few have mentioned them blocking the drains on the forum in the past.
Alright, that is a very fair point. This bike does run and I had it running pretty well last fall, I'll just clean this out as best I can and hope not too much fell into the cylinder. See, this is why I'm a member of this forum because there's so many people with far more exp than myself, and I REALLY appreciate everyone's advice and willingness to help out a novice like myself. So far I have serviced forks, carbs, brakes, new tires, shep method mechanical seal, and I'm working on pinehole leaks in the gas tank and I will be upgrading the electrical system to the NWT Marty. I got the advice when I got the bike to run down the maintenance list on the FSM, so I've been trying to knock all this out, I was at spark plugs when this all came up.Definitely not trying to dampen your enthusiasm but an awareness of the unique problems faced in engine overhaul on these bikes is advised. Parts are difficult to source, there are special techniques for successful sealing of water pipes and more. Personally I'd concentrate on getting it functional first, then testing electrical systems, water pump and associated parts, running gear, brakes, forks, tires,,,,, when it's a viable machine the heads n cylinders could still be removed if necessary.
