41 - 60 of 72 Posts
Reactions: carms40a
Discussion Starter · #43 ·
It's a great idea but I still need to bring the turbo up a couple more inches and hardline the return so that way it drains smoothly. I currently don't even like the setup I have now since the return line still goes up a little and then back down. I will take care of this when I install the new setup :D
Thought: Why not drill and tap the inspection cover hole for the oil return? You'll get more oil splash on the rotor, which may help cool the stator and lead to a longer stator life. Just a thought.
Charles.
chase were you as surprised by that illusion malbec turning purple instead of the dark maroon i thought it would be?
i looked like it would match the color of my naked 81 cafe gl1100
when i did them and it turned that color i just started stripping them again
Discussion Starter · #45 ·
Very much so, just because of the description and other customer photos I was really under the impression that the color would be just that. Instead I pulled out the peices then cool down and very shortly found out that it wasn't a dark maroon. I have even powdered it differently along with shorter or longer times in the oven and just couldn't get that red I was looking for. This was my last attempt (for now) and it's kind of grown on me. It's still a very cool color but I would really like to get that darker maroon if I could.
If you raise the turbo, you might run into issues with your fuel line going up hill. Also, be sure to put some insulation under your seat, you are about to have a 1000 degree seat warmer. You can get those insulated covers for the hot side of the turbo, that might help too.
Discussion Starter · #48 ·
If I do end up doing that I will just put in a low pressure fuel pump. I found out the whole seat warmer thing the first time I took it out for a couple hours. It doesn't get too hot but I am currently looking for a turbo blanket or reflective shielding to stick on the bottom of it.
If you have an airport nearby, better yet an aircraft maintenance base, ask around to see if there are some scrap pieces of engine insulating blankets. I would have access to some if I was still working. The stuff is super light, but very effective. It has a reflective foil-like outer face, and has lacing holes for safety wire.
Hey cool motorcycle. I'm building my motorcycle, what carburetor is installed? can you provide a link or a model for this carburetor?
The last post from the OP was 2 years ago, maybe he'll respond???
Discussion Starter · #58 ·
I'm really curious what the turbo lag is like. Also which turbo is that?
Charles.
The turbo is a Garret GT15, Lag isn't bad at all considering size of turbo and location. If you want instant response i would recommend going to a GT12 or VZ21 turbo.
Discussion Starter · #60 ·
Welcome back..cant remember seeing the build thread when originally posted...well done
good to be back! Well little update for the turbo build. The bike is under construction once again on a new turbo kit for Carb and fuel injection capabilities. Along with the new kit being built I decided to restore a CX500TC from the ground up. Once the new kit is finished both bikes will be dyno’d, road and track tested just as a fun comparison.
Tire Wheel Vehicle Fuel tank Automotive tire
41 - 60 of 72 Posts
