This last sunday i gotthe bike home finally but it was at night so i didnt get to work on her till monday. anyways, i pulled the sparkplug wires out and man the plugs where nasty. cleaned out the holes and put alittle oil down the cyclinders. got the tank off and cleaned it with acid to eat the rust that was in there, it was nuts not only did it eat the rust but the inside of the tank was smoking! before i did that though i toke off the petcock and ill need to get a new gasket of it. then i toke out the carbs and cleaned them up. i was really suprised at how clean the inside was even before i sprayed them down. the pistons moved with out much force and i could hear the flots movin around so i figured that they should be ok to get the bike runnin. if not ill rebuild them. pulled off the radiator, flushed it and spray painted the shroud covers looks much better. ill post up more pic's when i get some more time. got to get ready for first day at work.
you can kinda see the tank bakin out in the sun out in the grass
lot of work to be done, im going to polish up all the crome when i buy some wheels for the air guns.
