Hello--
So I'm one of those dummys that ordered all the parts for a 650 swap without seeing if the motor is any good lol. Decided to look at the motor today.
I got two GL650 motors for super cheap at an estate sale. One has a broken cam, most likely due to PO trying to get the cover off to do a cam chain replacement. PO then bought the second GL650 motor and never opened it.
I decided to use the second gl650 motor for my swap. Looks good on the outside, must be good on the inside, right?
Popped the oil filter cover off and there was about 1 teaspoons worth of what appeared to be aluminum sludge sitting at the bottom of the filter housing. I had the motor stored leaning on the filter housing, which is why the sludge prolly ended up in there.
Filter looked fine, and I didnt see anything gold in the sludge.
Took the "oil pan" off and it was clean, minus a tiny tiny bit of dirty oil.
Theres still cross hatching in the cylinders when using an endoscope.
Timing chain in this second motor is also shot.
Would the guides from the cx500 work in the GL650? I replaced the chain on my cx500 about 5000 miles ago, and it too has to get opened up to get the output shaft. Prolly going to reuse the 500 chain if I can....#cringe
Would you be concerned about the metallic sludge? I would assume its probably from the chain / chain guides.
One of the pics kinda barely shows the metallic stuff in the oil.
