Hello again,
Just when i thought i was ready to ride....i need to replace the mechanical seal. This will be 2/3 for the triple bypass!
I have coolant coming out the weep hole under the carbs at idle fairly consistently, so rather than put it off it's time to replace it. I will be using shep's method of swapping the seal from one cup to the other.
I need your assistance double checking i have everything i need and advice on parts purchased.
Will be using this Video as instruction an info from this forum
Replacement parts:
Mech Seal and polo mint - (yamaha 11H-12438-10-00 ) - off Amazon
RTV gasket maker to re-attach seal to cup
Is the pump cover oring necessary to replace if it doesnt leak?
Reusing copper crush washer and re-annealing it
Am i missing anything?
Question: For the mech seal itself - is this a thing i should be buying from Honda to ensure it lasts, or will the ebay/amazon Chinese version work just as well?
Thanks
Replacement parts:
Thanks
