On one of the bikes the ceramic disk came out of the impeller with the rubber part that holds it in.
Should I replace it with the one that came with the Yamaha seal?
I have enough to do them all, should I replace all ceramic disks or are they an item that does not brake down?
Also I bought Permatex Water pump & Thermostat housing RTV silicone gasket Will this do the trick well for sealing the mech. seal in the metal cup and if so can I use it to glue in the rubber holder for the ceramic disk?
Thanks,
Doug H.
Thanks,
Doug H.
