So the master cylinder for my front brake is leaking, just a bit. I fill it up with brake fluid and it takes about 3 weeks but the brake slowly starts to get mushy. I have looked and it is constantly moist under the actual cylinder and I cant find anywhere else that is leaking or wet so Im assuming its coming from there. My question is, should I replace the cylinder or rebuild it? I have heard a couple people say NOT to rebuild because it has to hold so much pressure that you don't want to mess with it. Has anyone done this? Do you guys have any recommendations? Also, does anyone have a spare master cylinder that they would be willing to sell or trade for something off my bike? I'm parting some things out like luggage rack, original handlebars and some other small things. I found a rebuild kit for like $30 but I'm not sure if its something that I should do or just try to find another one in good condition. Thanks for your help
Cody
Busy rebuilding my 1980 Twin disk system, the whole lot.
The leaking you are seeing is between the plastic pot and the Master cylinder itself. What has happened is, with age, the brake fliud migrates past the seal under the pot and when it comes in contact with air, it crystilises. Then over time the breaks the seal and the brake fluid can then migrate dirctly out under pressure.
Removed the lid, drain and the with effort, you can pop the pot off, it clips into place, I slipped a screw driver between the M/C and the pot to pop it off, just be carefull, the wider plate you can use the better as the Alu and pot can damage easily....There will be a rubber seal in the master cylinder, remove and you'll see the crystals. Clean out PROPERLY, get a new seal and refit.
I just replaced my pot, seals caliper pistons, seals, all bought off eBay. It took me awhile to scrape out and clean the master cylinder and you'll be surprised how dirty it can be. Don't be shocked to see a kinda slim on the inside, if there is then you'll have to strip down the calipers because for SURE they have the same slim inside which rusts away the pistons, pits them and then they start to leak, old brake fluid due to poor maintenance.
I've redone the WHOLE system and fitting braided hosing to remove any flex from heat as the original pipes being 30 years old look good but add heat, they shot.
