1 - 12 of 12 Posts
Hi,
My first post; my first bike. :)
I have a 1981 cx500d and I just replaced the stock exhaust system with the Mac 2 into 1, in black. I did not rejet the carbs and am using the stock air filter (not pods).
Everything seems to be running normally with the new system - no leaks, no black smoke. However I noticed after I took the bike out for a short ride, the finish on the headers had dulled and the right header had some very mild raised bumps at the bend.
My question is - is this normal? Or is it a symptom of not rejetting the carbs? (Or something else?)
Any advice would be appreciated.
David
I've been running a Mac on my 500C since I got it {7 years or so, it was on it when I got it}
The bike also has the stock airbox.
I rebuild carbs and often run them on this bike. It tolerates all jetting from standard up to about 85/118. Above this it gets too rich. Stock jets seem fine though. The bike is happiest on 80/118.
Discussion Starter #4
If it's gold, you should be fine.
If it's blue, you are running too lean.
Mac's almost always require a re jet.
Hi Timothy -
The finish on this Mac exhaust is black - I can't tell if the discoloration is gold or blue.
See pictures below for reference.
David
Did you buy that directly from Mac or a business, or is this a private party transaction?
That looks like paint bubbling to me.
Discussion Starter #6
That's a good call. I purchased it from Niche Cycles, which appears to be a reputable supplier, but maybe a follow up call to Mac is in order.
David
Discussion Starter #7
Timothy - you're spot on. Talked to Mac and it's likely contamination in the paint. Thanks for the help!
David
Hi,
David
I installed the chrome Mac on my 80C with stock airbox and factory jetting (78/112) Top 8 inches of pipes turned blue immediately within the first 50 miles.
I re-jetted to 85/118, the blue is still there but with a golden hue. Its now been close to 2 years and plugs look great. I would recommend that anyone running a Mac 2-1 use the 85/118 jets.
BTW. My 80c "Blue thing" is by far the quickest/fastest of all 3 of my cx/gl bikes. It's pull through the 6000-8000 RPM range puts a smile on my face every time I ride it.
I re-jetted to 85/118, the blue is still there but with a golden hue. Its now been close to 2 years and plugs look great. I would recommend that anyone running a Mac 2-1 use the 85/115 jets.
Considering rejet, are you using 85/115 or 85/118? thinking there is a typo going on there.
yes there was a typo ... fixed
1 - 12 of 12 Posts
