1 - 15 of 15 Posts
Does anyone have an munit diagram for a cx500 they did??
Having trouble wiring up the ignition side of it
79 cx500
Good!. So now the thing to do is to post your solution to help the next person with the same question.
Ultimate Upgrade
Here is my diagram I drew up and figured out, I am using the upgraded Rae-Sans ignition, MOSFET Regulator Rectifier and a Ultima Black Single Fire 3 Ohm Harley Coil.
Mike
Mike
Mike,
So the diagram you posted is a tested running system you have on your bike now? In other words, it is a known good diagram that others can copy if they have a similar configuration on their bike?
What made you go with the HD coil and how does it perform?
BTW, what model & year bike do you have?
Thanks for posting!
Mike,
Thanks for posting!
The HD coil was recommended by Murray to complete a full electrical modernized system. Yes it works very well. My bike now is a CX500 with a upgraded CX650 engine.
Sent from my iPhone using Tapatalk
The HD coil was recommended by Murray to complete a full electrical modernized system. Second question why would I take the time to draw it all up a post to to screw with people? Yes it works very well. My bike now is a CX500 with a upgraded CX650 engine.
@Mike, I'm not able to find a kill switch in your diagram. Did that just not make it on here or you choose not to have it on your bike?
The m-switch. Can be programmed to do both. Press once to power the system press and hold to start. Then double push to kill the system.
I should have labeled the start button. Start/Kill Button.
The ignition system remains unaltered, but receives power from the Aux output on the M-unit. A start/Kill switch will work with the M/unit, however, whether or not the stock Honda kill switch will work is another matter. I don't know for certain, but I do recall reading somewhere that it may not.
Ultimate Upgrade
Mike
Mike you bike looks amazing a true inspiration!
Thank you so much for uploading your wiring diagram you can’t imagine how helpful it is.
I’m planning on installing a munit blue this fall, putting together a list of parts that I’m going to need and drawing up a wiring diagram for myself, and I was hoping you could answer some questions for me.
I’m running a Rea San Hall effect CDI
Murray’s coils on plugs
Mosfet r/r and 8cell battery
so very similar to your set up.
In your diagram I see that you connect the 12v wire from the ReaSan to the ignition out put on the Munit I’m i correct? I’m assuming the green wire went to ground , brown to right coil and yellow to left coil just like you would with a stock harness.
I see on a previous post that you are using the kill mode from the Munit so did you leave the white kill wire from the ReaSan unconnected?
And I see a yellow wire connecting to your dash is that wire the tech rpm counter?
Thank you so much for your help
1 - 15 of 15 Posts
