I would like to know your opinion about this.
It´s said that nowaday´s cables (clutch, speedo, throttle or whatever) are covered on the inside with teflon.
This is also said to make additional lubing unnecessary. A "guru" even told that lube, with time, will collect dust and grime and make, for instance a clutch cable loose its light action, hence not immediately being fully pulled home by the clutch arm / clutch springs, thus causing clutch slip.
But, my impression is also, that speedo and tach cables (aftermarket) last longer, if they´ve had some thin oil soaked into them from above, before fitting.
Whaddaya say?
Sture
Whaddaya say?
Sture
