if i cut an inch or two off my springs around my shocks would that lower it until i get shorter shocks?
yes but its probally not the best way to go.
Are we talking front or rear?
On the front you can raise the fork tubes in the triple trees effectively lowering the front end. And on the rear you can set the preload to the lowest setting so you get more sag.
you might want to consider switching to Harley Davidson air shocks as i have done. you could lower the pressure and drop the rear, plus be able to change the settings in the future. Got my set on e-bay, 80$ with air lines and shraider valve. you'll only need to switch out the rubber bushings.
The shocks I have were advertized on E-bay as 2006 Electraglide take offs with only a few thousand miles. I hope so anyway as i would have no way to tell the difference. maybe a Harley guy could tell the difference. they were sold by a Harley dealer who had replaced them w/ a lowering kit which i assume is popular. They are 13 long, the same as our CX's. they fit like they belong there. The mounting studs are a different diameter so you will have to press out the rubber bushings on the air shocks w/ a socket and bench vise and simply replace them w/ the bushings from the CX's shocks. I mounted the shraider valve assembly behind the rt cover near the flasher can. I believe these are intended to be run at 10-25 psi. I find w/ loaded saddle bags and me solo @ 250lbs, 11-12 lbs gives a good ride. with my 130 lb son on the back I run them at 16 lbs. these shocks made a dramatic difference for my bike. My original shocks had 55k when i replaced them and it was like riding a pogo stick... sorry i don't have any pics. good luckAre you using the big black Electa-Glide shocks? I've seen those on ebay and wondered if they'd fit -- they look really thick.
what's the eye-to-eye measurement? Do you have pics of your set-up?
Thanks in advance.
