Drained my coolant today, well actually it was distilled vinegar but anyway... Normally when I lose something, if I have another project to do I go to that, and eventually I find whatever. So I put the headlight wiring back together and taped up a big mess I made of the harness. Still no Drain bolt. I have looked everywhere. EVERYWHERE! So, I need to do something about a drain bolt. I dont see a reason why I have to use a plastic OEM plug. Anyone have an idea for me?
On another note. I ran the motor again today to check the charging voltage. Getting around 15 volts, but that was without the headlight plugged in. When it was running there was a white misty like cloud. I thought it was just moisture, but then it was to much for to long to be that. Very white, very wispy. I'm burning the vinegar I used as coolant! Ok, so I didnt have a head gasket problem before the triple bypass, but after looking over the right head, I discovered I had forgotten to replace one of those smaller head bolts at the top right of the head. There was a hose that laid on top of the hole where the bolt should have been. So I found the bolt and put it in. I have forgotten this bolt before, it holds a bracket on for the thermostat or something. But I CAN'T put coolant in it now to run it and see if I have the 'white misty' protruding from my right tail pipe. I have a new head gasket if I need it but yeah. I'm so close but so far away. I need your input
Oh and when I step on the rear brake, my brake light turns off, but that's minor.
