1 - 6 of 6 Posts
1982 Honda Silverwing GL500
I recently got a 1982 Honda Silverwing GL500 but the gas tank has multiple pinhole leaks and a lot of rust inside. I've been trying to patch it with JB Weld and clean the inside with vinegar but I keep finding new holes and just want to get a new tank at this point.
Does anyone know of any tanks that would fit the Silverwing? I've been told a CX500 tank would fit but I have been unable to find one. I'm hoping to spend less than $250 if I can.
My GL500's tank had multiple pinholes too. I couldn't find a replacement but the wrecker I usually deal with suggested I take it to a rad repair shop and have it epoxy lined and 18 years later I'm still using the lined tank.
Apparently it is getting hard to find a rad shop willing to line bike tanks these days but a lot of people have had good results with POR15's tank repair kit so if the one from Keith falls through for any reason and you don't mind working with harsh, smelly chemicals you might want to consider that.
Thank you for all of the advice! I've already bought new tires but I hadn't thought to check the break lines. I'll be sure to double check all of the parts you mentioned as well as reading through the shop manual.
1 - 6 of 6 Posts
