Whoever suggested that simple key locks picked up at a hardware store could be used to replace vetter saddlebag locks thanks. I spent $6 today for two and each had two keys so now I have 4 keys for the lockable saddlebags. The only thing I wish I had looked at harder was the flat spot that keeps the locks from turning in the holes. My set wasn't flat enough so I ended up having to grind them and the bags down a hair with the dremel. Then all I had to do was bend up the latch bracket. A lot cheaper than getting vetter replacements.
I only wish it was as simple to replace mine on the hondaline bags. But I don't leave anything in them that needs locking up.
BS - did you look into a getting a locksmith to rekey your Hondaline bags? I've got one lock that is different than the rest and it would be nice to have the all the same
Thom
This is why among other things I went to the Vetter setup on my bike. No plastic or metal hooks in the back, bigger,
and a little more friendly to work on. Plus no chrome hinges on the outside to get all rusty. The plastic panels
are all removable for easy repainting. Best of all, if I come across a decent set of Hondaline luggage, I can still
remove the luggage and brackets and pop them in place. Best of two worlds!
Oh yeah, kinda nice to have a trunk with a big pile of brake lights on it.
Thom
Thom I didn't look into a locksmith for my bags but I probably should. What I did instead was just take the securing latch from the lock off the latch so I could use it. I do still have the parts so I can go back.
