1 - 20 of 31 Posts
Doe anyone have a CAD or simple line drawings of an '82 GL500I? Looking for something like a 3-view CAD drawing with front, rear and side views.
Done. Thank you.
Sent again to the email link in your profile. Hope you get this one.
Is that rectangle a wind deflector. Its right in front of the gas tank on the fairing. Or is the suppose to be the door for the fairing compartment?
Are there more angles of this drawing on photobucket?
I'm pretty sure that is a wind deflector, yes.
Joel in the Couve
That drawing looks like an add poster for all the Markland accessories ever made for the GL.
Did a little old-school cut & paste editing (using scissors an real paste!). Voila! A stock GL500I for us to play with! Enjoy!
Discussion Starter · #13 ·
Sorry 'bout the vertical ... seems like I goofed!
Discussion Starter · #14 ·
Possible paint for my restoration project. What do y'all think?
Discussion Starter · #15 ·
The white areas are actually silver metallic. The purple will also be a metallic. I'm not a good enough artistto make that readily apparent.
Discussion Starter · #16 ·
The white areas are actually silver metallic. The purple will also be a metallic. I'm not a good enough artist to make that readily apparent.
Is it me or is there a highway pedal attached at the rear of the engine and extends forward to the middle of the engine.
Discussion Starter · #19 ·
OK, I missed that. Ya caught me. The idea was to reconfigure the tricked out drawing to show the body work in it's stock configuration so I could use it for working on paint designs. I could still use views from the top and rear if anyone has them. Also, if anyone has any ideas for pinstriping what I posted, I'm open to suggestions.
Discussion Starter · #20 ·
A bit more added to the design. Tell me what you think. I can't to actually begin this project. Gotta finish a few other garage projects to make room.
1 - 20 of 31 Posts
