When I start my 1982 Gl500i when it is cold, the head light goes out but come right
back on when the bike starts, is this a sign of a weak battery? or is this just normal?
Ev
GL 500i
MI
Totally normal. There's circuitry arranged in a way that diverts juice away from the light so that the starter will have more oomph when it is energized. There are folks here who will explain exactly how it works. Their brains are more electric than mine.
Hoppy
Hoppy
Thanks for the reply!
Ev
gl500i
MI.
The START button has two contacts, one (normally open) in the starter relay circuit and one (normally closed) in the headlight circuit. When you press the button the normally open contact closes and the normally closed contact opens so that the headlight is turned off when the starter motor is running.
It doesn't actually divert current from the headlight to the starter as much as simply prevent the headlight from consuming power that the starter needs.
