I took my 81 Custom out for a ride the other day and drove it harder than I ever have before. I got the carbs all synced up by Larry and keep hearing that this bike can go above 6k easily so I thought what the hell. Sure enough something happens, just my luck with this bike. I looked down ans saw that the temperature was wayyy above what it usually is (even though my regulator is broken and it's always in the red, the needle was prettymuch up in the gauge past visibility.)
I parked it when I got home and smelled burning plastic... Who knows what that's from. But, I did find a pretty nice oil leak on the upper right side (clutch side) of the front crank case cover. Is the gasket for this readily available? Do I need to take the clutch and/or oil filter off to get the cover off? (I think I do)
Another thing I have going on is a coolant leak at the back of the engine where it's piped into the block. I was told that it's alot of hassle to fix it and just let it be, just make sure there's always fluid in it. I'm content with that. But now when I ride it, no matter what gear, when I get at about 3.5-4k RPM, I hear what I guess I would describe as a hollow sound that was never there before, and it's right below my crotch. Any ideas what it might be?
Another thing! I looked at the bike from a distance and I saw all kinds of fluid on the right side of the rear tire! only the right side too. This might be a drain hose or the coolant leak or any of that, just putting that out there.
Im going to look around the forums too and try to find the electric fan conversion too... but if someone could help me out with a link to buy the fan or anything, that'd be dope. I know the battery is 12v and most motors are too. Guessing I'd have to find a spare pair from the main power splitter or else I'll just have to tap in and throw on some mollex connectors or somet...
Any help or advice would be greatly appreciated! I like my bike but it's probably the biggest lemon I've ever purchased. But, I like it.
