Yes, we very much want to see the build mate.
that makes more senseRebuilt is a subjective term apparently.
I've seen it applied to CXs with camchain replacements, perhaps a triple bypass or just a stator replacement.
That makes sense, Doug, because it has run 38 tsd km.that's interesting that the engine would be rebuilt, wonder why?
I saw the pics, not pretty...That makes sense, Doug, because it has run 38 tsd km.
The CX 650 has an automatic timing chain tensioner and the chain has a life of max. 50tsd km. But I have also seen worn timing chain tensioner at less than 50tsd km.
Therefore, this is now the right time to also aim for a "controlled maintenance condition" as part of the rebuild. 👍
I generally open any engine that I don't know the maintenance history of.
You are welcome to look at this engine in the German CX forum. It has run just 33tsd km and looked visually like new. Even if the text is in german, the pictures tell you everything.![]()
The endoscope will not tell you everything about the tensioner.I also want to get a new endoscope camera to check the timing chain tensioner.
Thank you, I did read the thread. Very interestingYou can read about what that entails in this thread.
