So as my username would suggest I am new at this. Not just at becoming a member of a forum and posting things but all this wrenching. I recently purchased a 1978 Honda CX500 which the past owner never had running. But I was hopeful after I saw it was not all rusted and all the rubber boots were not all dried up and cracked from the sun. I had a friend who knows things abotu bikes help determine that the engine is not seized up and we tested for spark on both cylinders, which was present in both. I am goign to eventually check compression and all of that but I have never wrench on anything so I am learning technical terms and how to be a guy as I go.
I got the service manual with the bike and decided to start with taking the carbs apart to clean them up. They are the Keihin brand and the numbers engraved on the side are "26AQC7" , though between the A and Q there is an "A" in a box. I am looking to see if anyone would happen to have an extra, what I would consider a needle valve spring. I found one in the first carb but none in the second carb. I just don't feel like having to buy a who carb rebuild kit for one lonely spring. Please let me know if you can assit me. I will post picts of the new cherry once I get some so it can be open for ideas. Thanks for the help.
