1 - 10 of 10 Posts
Hi
Does anyone know if I can use the K&N Air Filters with an 1982 CX500 Eurosport. If I can't use them does anyone know of different aftermarket air filters that would be suitable?
Thanks
Keith
If you mean in the stock airbox, the CX650E uses the same filter as the GL650 so I would expect that the CX500E would use the same as the GL500 but I can't say for sure BUT it wouldn't be hard for you to look up the part numbers for the stock filters and see if they are the same.
FWIW, I use mine in winter (= extreme conditions) so I had to replace the paper filter every year. I didn't want to spend the money for a K&N or UNI filter so converted an original paper filter to accept a piece of foam filter material that I can remove and clean instead of replacing it every year
https://cx500forum.com/forum/build-threads/27923-eccles-never-ending-build-retroactive-2006-a-19.html#post1002861 (scroll down)(to put things in perspective, mine started out as a 650E that should have become someone's parts bike and last fall I replaced the engine, carbs, airbox &c with ones from a GL500)
According to CMSNL the same filter fits the following models;
CX400E 1982 (C)
CX500 1978 AUSTRALIA
CX500 1978 CANADA
CX500 1978 ENGLAND
CX500 1978 EUROPEAN DIRECT SALES
CX500 1978 FRANCE
CX500 1978 GENERAL EXPORT KPH
CX500 1978 GENERAL EXPORT MPH
CX500 1978 GERMANY 27PS TYPE
CX500 1978 GERMANY FULL POWER VERSION
CX500 1978 ITALY
CX500 1978 SOUTH AFRICA
CX500 1978 USA
CX500 1979 (Z) USA
CX500 1980 (A) AUSTRALIA
CX500 1980 (A) ENGLAND
CX500 1980 (A) EUROPEAN DIRECT SALES
CX500 1980 (A) FRANCE
CX500 1980 (A) GENERAL EXPORT / KPH
CX500 1980 (A) GENERAL EXPORT / MPH
CX500 1980 (A) GERMANY / 27PS
CX500 1980 (A) GERMANY / FULL POWER
CX500 1980 (A) ITALY
CX500 1980 (A) SOUTH AFRICA
CX500 1981 (B) AUSTRALIA
CX500 1981 (B) ENGLAND
CX500 1981 (B) EUROPEAN DIRECT SALES
CX500 1981 (B) FRANCE
CX500 1981 (B) GENERAL EXPORT / KPH
CX500 1981 (B) GENERAL EXPORT / MPH
CX500 1981 (B) GERMANY / 27PS
CX500 1981 (B) GERMANY / FULL POWER
CX500 1981 (B) ITALY
CX500 1981 (B) SOUTH AFRICA
CX500C 1982 (C) CANADA
CX500C CUSTOM 1979 (Z) USA
CX500C CUSTOM 1980 (A) GERMANY / 27PS
CX500C CUSTOM 1980 (A) AUSTRALIA
CX500C CUSTOM 1980 (A) CANADA
CX500C CUSTOM 1980 (A) DENMARK
CX500C CUSTOM 1980 (A) ENGLAND
CX500C CUSTOM 1980 (A) EUROPEAN DIRECT SALES
CX500C CUSTOM 1980 (A) FRANCE
CX500C CUSTOM 1980 (A) GERMANY / FULL POWER
CX500C CUSTOM 1980 (A) ITALY
CX500C CUSTOM 1980 (A) USA
CX500C CUSTOM 1981 (B) AUSTRALIA
CX500C CUSTOM 1981 (B) CANADA
CX500C CUSTOM 1981 (B) DENMARK
CX500C CUSTOM 1981 (B) ENGLAND
CX500C CUSTOM 1981 (B) EUROPEAN DIRECT SALES
CX500C CUSTOM 1981 (B) FRANCE
CX500C CUSTOM 1981 (B) GERMANY / 27PS
CX500C CUSTOM 1981 (B) GERMANY / FULL POWER
CX500C CUSTOM 1981 (B) ITALY
CX500C CUSTOM 1981 (B) USA
CX500C CUSTOM 1982 (C) USA
CX500D DELUXE 1979 (Z) USA
CX500D DELUXE 1980 (A) CANADA
CX500D DELUXE 1980 (A) USA
CX500D DELUXE 1981 (B) USA
CX500E 1982 (C)
GL400 WING 1981 (B) JAPAN
GL400 WING JAPAN
GL400C WING 1979 (Z) JAPAN
GL400C WING 1980 (A) JAPAN
GL400C WING 1981 (B) JAPAN
GL500 SILVERWING 1981 (B) USA
GL500 SILVERWING 1982 (C) USA
GL500 WING JAPAN
GL500C WING 1979 (Z) JAPAN
GL500C WING 1981 (B) JAPAN
GL500I SILVERWING INTERSTATE 1981 (B) USA
GL500I SILVERWING INTERSTATE 1982 (C) USA
This product fits to 74 models.
I have had a K&N in my 1981 cx for years. Love what is does. It still uses the original air box.
Did you change any jetting? The '82 GL500I I picked up last summer has a K&N, but I have yet to tear apart the carbs to check jetting. It runs pretty great overall, though doesn't always pull cleanly through the rev range.
I have carbs from the 1982 gl bike. I just remounted them into the cx500c 1981 frame system. I Just reset the idle jet screws. Not sure if the jets are different on the gl with the faring and bags to my cx500c 1981. The set up works great.
Hi
Thanks
Keith
I'm running K&N in my 82 GL with no changes. It may be more expensive ($50) but I think it's worth it. I put roughly 6k miles on it every year, so I change it each year. Yes it is washable but I would rather put in new.
Bob C.
I would suggest that you check the filtering capability of the K&N.
Last I checked, the K&N will allow fairly large particles to pass with a low efficiency. Sorry, I don't recall the exact numbers off the top of my head. But I do recall I investigated it as comparison to a standard paper filter. I did not make the investment in the K&N.
It seems wasteful to me to buy a washable filter and then throw it out instead of washing it. ...
Until I retired I put about 10,000 Km on mine every year, mostly winter driving & a lot of dirt roads when it was warmer so the paper filter needed replacing every year (I can't imagine a filter lasting less than 3 times that on paved roads when they aren't covered with salt & grit).
I got fed up with spending that much so I converted to a foam filter that I could wash out and re-use.
And no, I didn't change the jetting.
I have a feeling that a properly oiled foam filter doesn't let much more past than the paper one.
1 - 10 of 10 Posts
