The weather here has been just shy of perfect for being outdoors. The only drawback has been the wind that seems to settle in around 20-25 MPH. Temps have been in the upper 70's and low 80's with partly cloudy to sunny skys for the past couple of weeks. In this region, this is the "sweet" time of year. It doesn't last long before the mercury climbs about the century mark and the humidity goes along with it. I digress...
Decided to get out and enjoy some of the nice weather this evening on the bike. Went through the pre-ride ritual, and then started it up. As it sat idling, I heard a noise that was not constant and varied in intensity periodically. Not tappets and not a lower end knock; a quick listen at the back of the motor narrowed it to the cam chain. Okay, so the cam chain needs some attention. No big deal, we'll just make that adjustment and I'll be on my way.
Pulled the inspection caps, plugs, and rotated the motor to the appropriate cycle and postiion. Put a wrench on the tensioner bolt and found it was loose. "Ahhh, that confirms my finding of the cam chain making the slapping noise." Did the obligitory "adjustmet taps", and went to the torque the tensioner bolt. No tighty. Nothing. Not even a grab.
Perfect... No ride today, obviously. And before we can enjoy the above weather, time will have to be taken to dump the lump and find out what happened. The cam chain was adjusted about 300 miles ago by myself. I vaguely remember thinking that when I tightened the tensioner bolt back then, that it didn't quite feel right. It torqued down, but the wrench was in a goofy spot and I passed it off as being a "slip" rather than a fastener problem. I am not sure if it pulled the threads and it finally gave up, or it the tensioner bolt twisted and sheared; that will be determined when I get the cover off and get eyes on.
Is this a typical issue with these bikes, or am I going to be dealing with a difficult to resolve problem? I have noticed that the tensioner bolt doesn't appear to be available anymore. If it is the threads that have stripped, then a heli coil should take care of that (I am hoping this is the issue). Besides fixing the issue and a thorough clean up of any debris, is there anything else to be wary of?
The origional plan was to ride the bike for the summer and fall, then in the winter pull the bike entirely apart. Basically do a frame up freshen up/restore. Paint, polish, repair issues, replace bearings, bushings and seals, tires, hoses, open the motor and give it a freshen up (stator, cam chain & tensioner, clutch, seals, the works), rework the wiring, ignition (ignitech), carbs, and basically start next year off with a "new" bike. That is still the ultimate plan, so I'd like to get the tensioner addressed and get it back on the road as quickly and inexpensively as I can. The major stuff will be addressed this next winter.
My current plan is to yank the motor and open up the cover to assess the issue, any collateral damage and make the repair. I will also perform and autopsy of the oil filter to see if there is any metal (aluminum) present. If there isn't, a thorough inspection and clean up of the interior (assuming the chain has taken a bite of the case) will be done. If there is aluminum found, then how deep does the tear down need to go? Am I overlooking anything?
