While you can jump start by putting the jumper leads directly onto the bikes battery terminals {in the correct polarity of course} it can be better to put the earth terminal directly to the starter motor mount and the positive to the starter side of the solenoid.
Switch on the ignition and kill switch before you do this and the bike will crank as soon as the positive terminal is applied.
This takes much of the load off the bikes own electricals and battery which can be a bonus if the bike is disinclined to start.
Sure, the bike will crank over, but the fuel pump will not have primed the efi's fuel system, and the ECU may not accept some of its inputs as genuine, because some may be there before the ECU does its "power-up and check" routine.
Sorry, found this in "todays active content" and didn't realise you were referring to one of those newfangled turbocharged, computerised, EFI thingummies.
Though if there's any charge in the battery at all this still holds.
