Winter storage inside the filter apparently
Sheriff Bill working on the left side
Tank and seat off
Coil Testing
Rats nest wiring at the back
All cleaned up, with the JB welded cracked right coil off the bike
Tank, Front fender, tail light
My 3 month old was hanging with us and having a great time
The "holy" tank
Culprit #1
Trust me when I say that coil is TOTALLY covered in JB weld. It's a disgrace.... The other two issues are the tank is leaking on the left side in that spot and on the right side near the bottom of the tank. I've been recommended to take it to a welder to get it brazed, the local rad shop doesn't "coat" the tanks on bikes, there is minimal rust in the tank as it is not sure if they can fix it. The other major issue is the carbs leak...like a sieve. So I guess its off to oldbikebarn and order a gasket kit (or two?)
