I don't have pics at the moment, so I'll try to describe this as well as I can.
We cut the lip on the tank back as shown in the quick reference, and have the backs of the ears only very slightly the mounts that are part of the frame. Using allan bolts, we put in rubber bushings that are slightly larger than the mounts, rather than the Deluxe mounts or nylon bushings, but they're soft enough to distend and support the tank in the same position those other things would.
The rear of the lip doesn't go all the way down on top of the surface that has the hole in it, as the tank hits the frame before the lip can hit. The forks won't hit the tank (strange as quick reference shows the forks hitting the tank) and only the left side of the handlebar will hit, but that's probably related to steering stop issues.
It seems like the tank is slightly too tall in the rear, or just a bit too far back....even though it really can't go any farther forward,not due to steering stop issues, but due to the ears going fully onto the mounts. We can get the lip on the seat where it needs to go, but can't make it go far enough forward for the holes on the seat to line up again. We've decided that the only solution is to either cut the seat pan, or relocate the bracket that's under the seat.
I've never heard of this happening with this mod before, and search turned no issues with the seat up, so I'm making a new thread. Any advice is appreciated; I really don't want to cut anything other than the tank, but it looks like I may have to. Tomorrow I'll post pics if I have time to work on this again tomorrow.
