hey guys
my temp gauge has been intermittent for a couple years. i checked the voltage of the regulator, and it is right at 7 volts. i find it hard to believe a sender going bad. could it be possible that, once a load is on the regulator, that it quits putting out the proper voltage causing the gauge to quit working? just in case the reg is bad, i've purchased the neccessary materials to solder up a replacement. since i've recently converted to an electric fan, it's important that the temp gauge functions properly.
thanks for any help/suggestions in advance!
