I bought a 1979 CX500 Custom and all I need to get the bike running is a new stator assembly. If you have or know where I can get one that works please let me know.
TIA.
TIA.
David Silver Spares USA - Honda CX500 CUSTOM 1979 USA Generator stator not including pick upsI bought a 1979 CX500 Custom and all I need to get the bike running is a new stator assembly. If you have or know where I can get one that works please let me know.
TIA.
The bike cranks and lights work but the spark plugs don't fire. I've tested the stator wires and have removed the old and damaged one.David Silver Spares USA - Honda CX500 CUSTOM 1979 USA Generator stator not including pick ups
what issues are you having?
i know the cdi stators go bad, but ive never heard of a completely failed one. usually when theres a no spark problem its the kill switch. did you try cranking the bike with the kill switch unplugged?The bike cranks and lights work but the spark plugs don't fire. I've tested the stator wires and have removed the old and damaged one.
The stator was broken. It got caught in the flywheel and ripped the wiring. The kill switch is fine. I don't know how it happened I bought the bike in this condition.i know the cdi stators go bad, but ive never heard of a completely failed one. usually when theres a no spark problem its the kill switch. did you try cranking the bike with the kill switch unplugged?
huh. that is odd. how are the magnets? and....you should totally post a picture of the stator when you got a chance.The stator was broken. It got caught in the flywheel and ripped the wiring. The kill switch is fine. I don't know how it happened I bought the bike in this condition.
The fly wheel is fine. Do you know where I can get a new stator?huh. that is odd. how are the magnets? and....you should totally post a picture of the stator when you got a chance.
When the low speed source coil fails the bike will not start. That is a common failure as the stators age. Tech in Training did you check the stator by measuring resistances before removing the stator? How to check or test the stator and pickups on a CDI Honda CX500 | MotoFactioni know the cdi stators go bad, but ive never heard of a completely failed one. usually when theres a no spark problem its the kill switch. did you try cranking the bike with the kill switch unplugged?
id be curious to see the high speed vs low speed coil failures. i personally had a high speed failure on a 1 month old stator...When the low speed source coil fails the bike will not start. That is a common failure as the stators age. Tech in Training did you check the stator by measuring resistances before removing the stator? How to check or test the stator and pickups on a CDI Honda CX500 | MotoFaction
You can have your old one rewound for approximately $140.I bought a 1979 CX500 Custom and all I need to get the bike running is a new stator assembly. If you have or know where I can get one that works please let me know.
TIA.
