1 - 12 of 12 Posts
Hi i hope you gut dont mind a question from a newbie,i have just aquired a 1978 cx500 which is quite a bad state at the moment and im hoping to restore it but the problem i have with it is The ignition wires were pulled out of the connecting block that the ignition key normally operates and i dont know which colour wires should go to which connector. There a 6 connections and 6 wires, a green, red and a few black/brown colours.
Does anyone have a diagram or even a photo of the connections on their bike so that i can safely reconnect the wires without making more problems for myself by cooking something!!
thanks very much for any help
Rob.
The main wires are the red, black and green
Red - power from the main fuse
Black - power out to systems
Green - ground
Theres also a black/white cable which has to be grounded in order to
stop the engine and this is done when the switch is turned to off
and the b/w is shorted to the green
Browny wires are for the parking lights which I never bother with meself
and never used them in the ign switch
there's a diagram of how the switch works around somewhere
I did occur I may be helping someone hot wire a CX for larcenous purposes
but then I thought What self respecting tea leaf would nick an old CX?
Hi ive managed to sort the wires out thanks again for the info,and im trying to source an ignition switch i have found one for sale but it only has 5 pins in the multiplug and my bike has six,could i still use this ignition?and what is the extra wire for? any help would be greatly appreciated thanks
Hi there Bobsport ,I am searching for an answer to the same question , did you ever find out if the 5 pin can be used on a six pin harness? I would imagine you have long since finished renovating your cx and you are enjoying riding it.
Staff
Thanks for the swift reply J.C. unfortunately I cant swap them over as I have a damaged bottom part (sounds nasty) I will source correct switch
staff
P.S I hoped it would be possible to just swap the wires around on the cx 6 pin plug
1 - 12 of 12 Posts
