1 - 2 of 2 Posts
Good morning, I just bought the CX HALL FULL KIT for my Honda CX500.
I want to upgrade the full system by replacing also the stator, rectifier and battery (lithium).
Could you please recommend me what equipment I should purchase that will work properly with the Rae-san kit that I just purchased? Links to suppliers and models would be highly appreciated.
(Could these link below works fine?)
Thanks to whom will answer
STATOR: Stator ST340 | Caltric
RECTIFIER:
BATTERY:
I'm not familiar enough with the parts you have linked to to give an opinion (personally, a lithium battery would not be an upgrade for me) so I'll leave it to others to post opinions about them.
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. Check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet). If your bike still has the original rubber brake lines (should be replaced every 2 or 3 fluid changes = 5 or 6 years) I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid). And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
BTW: The best advice anyone can give you about customizing any vehicle is to get it safe & reliable in more or less original condition and use it for a while before you start making any changes so it can tell you what changes it needs to make it do what you want/need better. That approach almost always results in something you actually want to keep and use but making changes based on style or on what someone else (who may or may not really understand how the changes affect the way it works) has done often results in a piece of expensive yard art that you can't stand sitting on for more than a few minutes and might even be dangerous.
1 - 2 of 2 Posts
