More likely the engine has been replaced with one from a newer bike.
Two different ignition systems were used in this family of bikes, the Capacitor Discharge Ignition (CDI) as used on all CX500 models except CX500E and 1982 only CX500C and the Transistor Amplifier Ignition (TI or TAI) as used on the GL500, '82 CX500C, CX500E and all CX/GL650 models. The TI system is powered by the bike's charging system, which has a pretty standard 3 phase (charging only) alternator. The CDI is powered & triggered by extra windings on the alternator's stator.
(Note that, while both stators have the same footprint, the TI stator is rated for 252W but because so much room on the CDI stator is taken up by the special windings there is only enough room left for a charging section rated at 150W)
I believe that an Ignitech ignition made for a CDI engine can't be adapted to work on a TI engine because it needs some of the CDI stator's special windings.
Note to Blocker1, Thunder Muscle and any other new members who see this:
NOTE that the paperwork in the UK and some other parts of the world shows the year first registered, not the model year (US and Canadian papers show model year but I have been unable to find out which Australian paperwork shows). This is important because there were changes from year to year and the wrong year's information may not be applicable to your bike.
