1 - 2 of 2 Posts
hi all, am i right in thinking the screw/knob at an angle of about 45 degrees behind the fast idle/choke stop.
is the adjuster to set the idle rpm when the motor is at normal operating temp.
if so , is there a tool for the job because i cant get my fingers to it .
or is it long nose pliers?
thanks mark
Hi there, I'm not a turbo owner, but if it's like the CXc you might want to try putting a piece of hose over the end to extend it a bit. On the carbed CX the choke knob is Choking at full out. At partially pulled it's just upping the idle speed while warming up. I have a feeling that your turbo is different.
The Extending of small knobs and adjusting screws with a piece of fuel line or heat shrink comes in handy on a lot of mechanical minutia...
1 - 2 of 2 Posts
