That's strange, but OK. You are better off not using any of the brass from the kit unless the kit is genuine keihin or your existing parts are actually damaged. Ditto the float needle.
I mostly only ever replace the float bowl gaskets, O rings, ACVs and the accel pump parts if fitted.
If not keihin the brass is probably substandard as are the float needles.
