1 - 10 of 10 Posts
Finaly took the bike home tonight. I love it. I skipped class since I know what's going on for the most part and mounted my tires.
Getting the old ones off was pretty time consuming. Silicon, some hacksawing, swearing, sweating and finally pulling it off with my own arms freed the front wheel.
Mounted my pirelli and balanced with half an ounce of weight. Then the rear, silicon was all I needed. Came off under a minute and threw the new rear on. I didn't bother balancing it. Just placed the dot on the valve. Checked all my bolts and fired it up. Went around the block and adjusted the rear brake and took off 13 miles home. Loved all of it. Worth skipping auto trans class.... Me thinks so!
You better not let the excitement of a new bike interfere with your studies. School is expensive, and if you don't graduate, jobs are hard to find. The bike will always be there when you finish class. Plus, I don't want a guy that was skipping class working on my auto trans.
There is a mind boggling amount to auto transmissions. I took the class a few semesters ago with a terrible teacher. This time I'm taking in all the explained details. Pretty fascinating.
On a side note do Honda CM400A's have torque converters? This class kinda makes want to gut one to see how they work.
I can understand the excitement..... just don't make a habit of it
If I could skip WORK for ONE DAY to work on my tank paint/ touchups, I'd do it in a heartbeat! LOL
Thanks for the link. I just want to the inner workings of a hondamatic.
I guess an auto would have to have a torque converter and a flexplate.
Nope. There is such a beast as the turbo clutch-o-matic, for one thing. Likewise, the original GM Hydromatic used a fluid clutch, not a torque converter. You would also be leaving out all the world's CVTs, which do just fine without a torque converter.
I remember reading an article that talked about the CHIPs using the 750A for a patrol bike for a number of years. The transmissions lasted through 3 engine rebuilds. They weren't the fastest by any means, but they were extremely dependable for that day and age and they were fast enough.
I lived in California in the '60s and '70s. Saw CHiPs and local departments mostly riding KZ1000s and some Harleys. Just because I never saw them don't mean some departments didn't have a 750A. Mine would red line at about 100mph. It took a while to churn the oil in the torque converter up to that speed. That was plenty fast though as the highest speed limit anywhere in California at that time was 55mph.
1 - 10 of 10 Posts
