1 - 11 of 11 Posts
1980 CX500C, 79 Chopped Shovelhead, Mixed years Zuki Rockcrawler Chopped 32 Ford 3 window coupe
I'm making rear struts for my CX500. At what angle does rear shaft angle become a problem? I've seen picture of bike stating it has 8 degrees up driveshaft. Really no other info on the build. Will this vibrate or kill joints? New to forum and shaft drive bikes. Always been a chain guy. Belts are for pants! Any insight is welcome.
, other than " that's stupid!" Thanks in advance. Peace
Thank you. I've seen that some where else before. My intent with this bike is just around town putting. I'm building this for me to keep and never see highway riding it. Have other toys better suited that. This being said. Everyone feel 4.5 degrees is the max angle?
CX650C
You can see my Bike on the Avatar. Driveshaft ist strait of the engine. Shocks don't do too much. Problem is Clearance of the Forward Rests.
Remember that if you replace the shocks with struts the tire will be the only suspension and that can cause problems of its own.
Thank you everyone for the input. In the stable we have a 79 Shovel ridged with 12 over Sugarbear springer wide turns and rough rides are nothing new. Thing about choppers, they don,t handle well, they don't stop well, but they do look good with a hot girl on the back and sitting at the bar! (just not to long at the bar!) Have a new set of Kenda K673 mounted on stock wheels. 100/90-19 front and 150/80-16 rear. Wanting to get rear height set so I can do the neck rake. Not my first time around the block, so no freakin out at me. We've had our frame jig for 20yrs and know how to use.
it well. We've built a bunch of frames from scratch and stretched and raked more than we remember. Fab work, we got that! We are how ever are virgins to shaft drive and water cooling! Until now water was for washing and wet Tee shirt contests! First item bought for this project was the factory service manual, so we're good there. many of the cafe builds we've looked at are very well done and skill levels are up with the best fab people out there! I'm sure some of that flavor will show up in this build. So back to the original question. Anyone used more than 4,5 degree up angle on the swingarm?
Anyone else with thoughts or experience on this subject? Thank you again to those who have shared their knowledge and insight. We do appreciate the help.
The post Mike linked to pretty much says it all. When you have been around the forum for a while you'll find that Murray understands how these bikes work very well and what he says can generally be considered trusted information.
BTW: Don't forget to add your location and your bike's model and year to your profile.
Well 4.5 it is then. Thank you. I can't seem to update my profile? Life goes on. Peace
Did you follow the instructions at this link?
No, I did not. I'm kinda blind some times. I will though. Thank you.
signed, some time blind guy
1 - 11 of 11 Posts
