I've realized I get nothing from my horn, and I'll need it for a final road test, does anybody have any recommendations on where to start diagnosing it? I pulled the switch apart before and it was ok.
I had the same symptoms. You might try taking the horn off and verify it is funtional using a 12 volt battery. My problem was a broken ground wire just guessing someone pulled the connector off the horn using the wire. Make sure you have 12v at the horn might be the easiest approach.
