1 - 7 of 7 Posts
This is great! - Are this the actual colors of the wires as they are on the bike?
The colours are chosen to be as different from each other on the diagram but Blue /white is shown as a blue line with white stripe etc. The thicker lines are ony to get the colours in, not heavier wires Also, a bit that had me chasing about. The diagram is wrong at the solenoid. That wiring could never work. (unless someone knows better)
The line on the bottom of the diagram says it is for both the GL500 and the GL650. This is great. I thought they would be close and was going to use it for my 500 anyway.
Thank you. I've saved it to the photo folder, will probably use it when I can get the bike out of storage where I work.
I agree about the start relay (solenoid) wiring.... the RED and R/W wires should go to the Battery +, not the starter side of the relay. my Haynes manual has the same thing
1 - 7 of 7 Posts
