1 - 10 of 10 Posts
I am the proud owner of a 1979 cx500 custom. After following some guides on here- new oil, battery, plugs, radiator fluid, 7volt supply, clearing out the animal nest in the airbox, new filter and a new ignition switch ( previous owner passed :( ) she fired right up! dumps gas out the overflow and chokes under load unfortunately. Working on rebuilding the carb but idle jet mixture screw needles were previously broken off close to the tips. Might replace them to be safe. Next step is new front fork oil and possibly springs. Building for my 5'4'' partner in crime so we've also added ~1 inch shorter rear shocks, shaved the seat quite a bit and lowered the front triple tree ~1 inch to match the geometery. Any advice is much appreciated.
1978 Honda CX-500.. a work in progress
Welcome. I just cringe when I see the condition of neglect people let some fine machines get too. Thanks for being a rescue-er.
For fork springs...unless you are doing all the internals and fitting racetech valves etc.... go progressive type springs...good ride for most conditions...lots of brands eg wilbers, ikon, or just "progressive" brand that was S&W.....
And o course a fork flush and oil change...
And welcome!😀
Reactions: TommyW
Welcome to the forum and good luck getting your bike up and running and on the road!!
Reactions: TommyW
1 - 10 of 10 Posts
