I've read several posts on testing my gl650I stator but am having trouble understanding my results. I checked the resistance on the 3 yellow wires in pairs and all tested like they should. I then checked from ground (negative battery terminal) to each of the yellow wires. I was surprised to find continuity to ground on each of the yellow wires. I read that means my stator is bad. So, I then put my voltmeter on the battery, it read 12.2V. I started the bike and held the rpm at about 2000 and the voltage read 14.7. Is there something wrong with my stator ? Should it be replaced now, or wait until the charging stops........
Thanks
Thanks
