1 - 3 of 3 Posts
after rebuild and initial start up and run for a while, oil is leaking out of the hole that is cast in the side of the head. Any ideas why?
Are you referring to the hole which lets liquid drain from around the spark plugs? If so, check under your plug caps for oil and check that the round seal under the valve cover is present.
1 - 3 of 3 Posts
