1 - 7 of 7 Posts
Without context, it's hard to say. I think the proportions are wrong for it to be a mixture screw spring.
If you separated the carb bodies, it might be from the balance adjuster.
my vote is either the sync/balance adjuster or the idle screw
Where in Canada are you? Someone might be close enough to look at it in person...
Speaking of which, welcome to the forum. Please add your location and your bike's model and model year (there are significant differences so it helps to know which you need info about) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Since the OP only showed one spring it may mean that there is only one such spring in the carbs. If so, that would rule out the idle screws and leave spring on idle speed adjuster, spring in the accelerator pump, the spring on the carb balance screw. Or I'm making a false assumption and there are actually two springs.
1978, Honda CX500
i think it is the idle mixture screw, that goes on a pointy needle, with a washer and a small o-ring.
Make sure, you remove the O-ring if you are replacing.
1 - 7 of 7 Posts
