Have you looked for Kenda or Shinko?
I will ask about those. Any particular type of shinko or kenda?Have you looked for Kenda or Shinko?
Depends on your intended use on road dirt etc. For on road shinko tourmaster 230 . I've had good use from Kenda Challengers .I will ask about those. Any particular type of shinko or kenda?
This was exactly what I was thinking, the tyres will age before they wear, in my case. I see a pair of 404s for $162, seems like a good deal. Incidentally, does anyone know what was the original tyre circa 1979? Not that it would still be made or that I would try to match it, but just out of interest.Something to consider: Lower priced tires from companies like Kenda, Duro & Shinko usually grip & handle about as well as higher priced ones but they wear out faster.
The rubber gradually hardens to where it can't flow around the asphalt to grip, especially when it is cool or damp so motorcycle tires should be replaced after 5 years whether they are worn out or not.
Depending on your expected annual mileage it is often wiser to buy less expensive tires that will wear out before they age out instead of ones that you paid so much for that you won't want to throw them out in 5 years (or 6 or 7) because they still have lots of tread.
