I just bought and installed today a set of Oxford heated outer grip wraps. They installed extremely easy, the only semi-difficult part was wrapping them around my grips because my grips are already pretty fat. The wiring is in several sections with quick connects on each section, so I'll be able to take the wraps off the grips and disconnect a short section of wire and leave everything else hooked up. They connect directly to the battery and have a toggle switch for on/off so it is possible you could drain the battery if you forget and leave them on. Maybe later I'll wire it into a switched power wire, for now I'll just make sure the remember to turn them off. The toggle has a bright green LED so it's pretty obvious when they are turned on, and they get HOT pretty quickly. I had them on for only a couple minutes and they got hot enough to be uncomfortable with bare hands. They cost $50, so overall I'm happy with them so far but we'll see what it's like riding to work tomorrow in 35F temps.
My question is: do I need to worry about battery drain while riding? In other words, does my CX have enough spare juice to deal with these grips without any stress? I just topped off my battery with distilled water and charged it before I installed these grips, so assuming I remember to turn the toggle off these won't leave me stranded with a dead battery, right?
