Recently had the main fuse blow so I changed it. But with my luck I left it parked outside and looks like somebody tried to steal it because the starter/kill switch was ripped off the handlebars. Kill switch still works but not the start button, have to touch wires to start it. Problem now is that my headlight won't light up at all nor the left side running light.
Have little electrical know-how so any help is appreciated.
the headlight is wired thru the starter button so when the damaged the right hand control they killed it replace the entire control they are not hard to find
the side light does not go thru that control so you may have to trouble shoot and see if a wire got cut or pulled out of a connector
Discussion Starter #3
Would you know where I can find one? Would another control work?
