1 - 3 of 3 Posts
Hello, i found a 600 dollar running GL500 all there just looks rough. I been reading the forums for some time and would like to thank you all for the knowledge i have gleaned :)
I have found the problem but i named this post as such so as to help others that are having issues with the wiring.
Long story short i did check the fuses first-but not well enough-4 hours of multimeter work later i traced it back to the fuse box. The tangs that hold the fuses in was slightly corroded and they were loose as well as one of them fell apart when i removed it. Was needed maintenance anyways as i opened and cleaned all the related switches, plugs and contacts have all been dielectric greased. Runs great and everything works but this thing looks like someone stole it and road it offroad for 2 weeks straight. The fun begins.
Take some pics of "starting point"....if you choose to post you will get views....;)
If you choose not to post....you can later sit back with a beverage of choice and reflect on your rebuild.....
1 - 3 of 3 Posts
