I just bought myself a 1983 CX 650 this sunday, even with a fully charged battery it barely turns the motor over and the headlight goes out, now since I just bought this bike I know practically nothing, it does start and run. I took my starter out and apart and it was full of old brush debris, the three tangs on the plate were arced and pitted, these are basically the only pathway to the rear aluminum ground section of the starter, I only scraped them clean and bent them slightly upward, tomorrow I will make the ground strap bypass mod. I say this because it still will barely turn over. I only have an hour to do all this as I am the maintenance supervisor at a concrete batch plant in Alaska.
On something unrelated I popped the main fuse and I may have a fried regulator, one of my fellow employees accidentally turned a large charger on high while it was hooked up to a standard battery while I had a pair of jumper wires to the bike battery, just something I have to troubleshoot.
From what I see the whole bike grounding source goes from the negative post of the battery and then to the upper starter mounting bolt...I wire brushed mine before I attached it, but I may add yet another separate ground to the frame as well, probably up to where a main ground bolt for a wire harness is.
Right now my next step is to do the internal ground fix, bench test the starter and then make sure the ground path everywhere is good.
I have a feeling the ground from the battery to the starter bolt is not at its best, might be corrosian I have not cleaned on the bracket, it may not be getting on through to the rest of the frame.
So this almost sounds like we have identical problems.
