Well I think that says it
1979 Standard CX500
Let's get all the standard stuff out of the way:
New head bearings. Plus just re-adjusted after initial fitting and rides.
New tyres.
Front bearings feel good.
Yokes correctly tightened; not triple potato chops or whatever my friends across the pond call them
New fork oil with now equal quantities in both forks; certainly wasn't prior to my ownership.
Taken rear suspension preload up a notch.
Definitely worse with top box fitted. So I am beginning to think this might be standard for the model. Transalps certainly shake\tank slapped if you let go with anything more than a rear rack fitted.
Before I put it down to that's the way it is, any other suggestions? More pronounced around 30MPH but detectable at most speeds.
Thanks
1979 Standard CX500
New tyres.
Thanks
