Hi all, so I'm attempting to replace the handlebar controls on my '80 CX500 Custom, but running into a couple issues with the aftermarket replacement unit I got. Any ideas on fixes for these, or would getting a set of CB/CBR controls give me a better starting point?
- Kill switch working, but reversed
- Starter switch only has 2 wires instead of the 3 wires in the factory controls, and these simply connect together when the switch is pressed, rather than disconnect ground from one of the other wires, as the stock control appears to do
- Turn signal switch doesn't allow for front running lights to work
