Yesterday, I finally got the stubborn heads off the freebie parts engine that I acquired last spring. My rubber mallet wasn't up to the job, but a 2x4 and a BFH got it done.
When the left head came off, I thought maybe this was why the crank won't turn:
Ouch!
Then I got the right head off:
That powder is a mix of rust and oxidized aluminum. I think this is the side that didn't have a spark plug when I got it.
I blew it out, tipped the block so the cylinder is vertical, and bathed the piston in penetrating oil.
This piston is so completely corroded in place, the fluid is still there after 24+ hours.
Then I picked out the pieces of the shattered piston (and the slightly twisted connecting rod) to find the real problem.
Just above the empty journal, you can see the clamp from the left conn rod, wedged between the crank and the engine case. Below the journal, and to the left (forward), you can just see a fragment of the piston skirt lodged in the transmission. If I could disconnect the right conn rod, I might be able to turn the crank backward enough to free the clamp, but I can only reach one bolt with the transmission installed. I can't extract the transmission without removing the fragments of the piston from the gears. I've tried driving down the frozen piston with a board and my BFH, to no success.
So, I'm stuck. The only possibilities I can think of are chiseling out the right piston to (possibly) free the crank, or cutting slots in the ends of the transmission assembly bolts to remove the transmission plate and extract the rest piece by piece. I don't know if any of the lower end parts are recoverable, but I'd like to get all the iron out before I recycle the lump.
Any other ideas?
Thanks,
R
P.S. As to what killed this engine, I wonder if it wasn't an assembly error, like under-torqued fasteners on the left conn rod. A number of things suggest that this was a low mileage engine. I believe the guy I got it from used it as a rear cover donor for the stator. Everything else appears to be undisturbed.
Ouch!
Any other ideas?
Thanks,
R
