Greetings from a new rider!
338 Views 13 Replies 5 Participants Last post by  Sidecar Bob
Hi all! Just got my CX500 in a ridable state. I believe I'm the 3rd owner of this lovingly maintained machine. Looking forward to the many adventures to come.
Reactions: 3
1 - 14 of 14 Posts
Welcome to the CX forum
Good looking bike
What part of the country are you from
TLD 🇨🇦 🇩🇰
Thanks! it's gone some silly quirks which makes me like it even more.
I'm westcoast, in the Vancouver area.
What kind of "quirks"? Do you mean the unusual design or is it doing something odd?
Welcome to the forum. Please add your location to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Note that while aftermarket shop manuals are pretty much necessary for people without factory training to work on a lot of makes & models of bike the FSMs for the CX/GL500/650 family of bikes are so well written & laid out that the FSM is really the only book you need and and the aftermarket books are secondary references at best.
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. Check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet).
It looks like your bike may have the original rubber brake lines, which should have been replaced every 2 or 3 fluid changes (= 5 or 6 years) so if your bike still has them I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid).
And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
Reactions: 1
Nice, thanks for the heads up! Luckily the guy I bought it from included the original manual, so I've been reading over that in my spare time.
As for quirks, one example is that one of the previous ownes deemed to fit air horns onto it and wire them to the main horn button, while keeping a smaller switch for the OEM horn (which still works fine). I recently got it back from a local shop, where they changed the ignition, ar filter, battery, spark plugs, and both tires.
For now, it runs and I'm using it to learn. I'm inspecting and refreshing components as I go.
What exactly do you mean by "changed the ignition"? Are you referring to the keyswitch (which controls power to everything so "ignition switch" is really a misnomer) or something in the actual ignition system?
Yeah, the keyswitch. The original was ultra loose, so power would cut off if the key was moved. Installed an aftermarket keyswitch and now the bike starts on Acc, while On kills the engine. It's kinda jank, but I like it this way tbh
Maybe a switch for the TI system. They're easier to find, as the old points-fired Goldwings use them, too.
Just don't turn it to Park....
BTW, TI GoldWings use a keyswitch similar to the one for the GL500 but with a longer barrel.
hah yeah that's exactly it
Shops that make mistakes like that because they don't understand the bike they are working on are one of the reasons I recommend learning how to do the work yourself.
yeah, I'm feeling chill about it. as long as the bike runs safely, I can iron out the kinks as I go.
If you are going to ride it like that make sure you take spare fuses so you don't get stranded if you turn the key to Park.
1 - 14 of 14 Posts
