1 - 7 of 7 Posts
I use a rubber Camping mallet to tap and break the head gasket seal.
Note:Before you do remove the 10mm bolt in the front of the cylinder.This drains the coolant jacket around the cylinder otherwise you will get coolant all over the place when you remove the head.
Also prior to reassembly the head bolt holes MUST be totally cleaned out otherwise the head gasket will fail when re-torqued up.
This video will help as well,
http://www.youtube.com/watch?v=S1Bsc2zyihU
HTH
Your right not to pry between the two faces
thas bad !
I've whipped a few heads off and did one recently
theres a few places where the head overhangs the block
and with a suitable choice of lever/lump of wood you can
apply a bit of leverage to break the grip
If you get it to move a bit, dont try and do it all at once
wiggle it about then try lifting from another point then you'll
find it frees up nicely
i put the plugs back in,and turn the engine over via the front 17mm nut.use the commpression of the engine to help you.tapping as Reg said
Well I finally got the dang things apart...I broke two new rubber mallets in the process they where stuck that bad but they finally gave it up. Thanks guys.
Damn they must have been really stuck.I've had a couple of nasty engines off Ebay but even they came apart with a swift mallet crack.
Glad you got there
1 - 7 of 7 Posts
